Was just wondering what the plans are for developers wanting to use Visual Studio 2026 for making add-ins? I suspect it may be for version 3.7 and beyond.
Just curious to know 🙂
VS 2026 will be supported at 3.7, the next release of Pro.
Running Visual Studio 2026 v18.1 with ArcGIS Pro SDK 3.6 at the moment.Haven't uninstalled 2022 yet though😁
and theres no problem with using 2026? Do the VSIX templates and utilities work?
I'm only debugging pre-existing Add-In projects at the moment, that seems to work at least.
I had to report my findings, I had install 2026 on a new machine. I can report creating a new add-in seemed to work with the ArcGIS Pro 3.5 SDK along with debugging an existing one. However, I have had one annoyance where I'd get the error below every so often when rebuilding a solution. But a subsequent build works fine.
1> Failed to load the dll from [C:\Program Files\dotnet\host\fxr\10.0.3\hostfxr.dll], HRESULT: 0x800700C11> The library hostfxr.dll was found, but loading it from C:\Program Files\dotnet\host\fxr\10.0.3\hostfxr.dll failed1> - Installing .NET prerequisites might help resolve this problem.1> https://go.microsoft.com/fwlink/?linkid=798306========== Rebuild All: 1 succeeded, 0 failed, 0 skipped ==================== Rebuild completed at 08:20 and took 05.551 seconds ==========
