Yes, this would work if I was using several individual filter widgets. Those vertical alignment options, as well as the "gap" and "padding" settings would allow you to customize the spacing.
However, when you have a single filter widget with several different group filters configured in the single widget, there is no way to edit the spacing between those filters.
Have you tried placing these filters in a column widget? There are 6 different types of spacing you can do for a column (start, center, end, space around, space between, space evenly).
Sign in to post, follow content, and more. New here? Register for free.
