Hello Esri community,
We have recently started using Esri field applications a lot more, especially Survey123. I am still learning how it works, particularly how to manage data once field activities are complete.
For example, I have a survey that is only used during the summer. When all the information is collected in the field, I export the data (+ images) and transfer them to my colleague (for analysis). After that, the survey becomes useless until its next use. However, I realized that this was consuming credits unnecessarily.
How do you handle this? Do you delete all the surveys you receive to have an empty feature layer? Do you delete everything, including the survey? Or is there another way to avoid consuming credits while still keeping the data on ArcGIS Online?
If option 1, how do I delete all the surveys received at once? (I haven't seen the option to do this other than one by one).
I know this is a pretty basic question, but I hadn't really paid much attention to it before. Thanks in advance for your advice 🙂
Laurie.
