Created the first custom widget using Arc GIS Experience Builder V1.12 and then deployed to Portal for ArcGIS 11.2 as an item.
Now, when the widget gets loaded in the Experience Builder application - I am seeing the following message regarding the widget.
index.js:2 The widget, located at https://xxxxdev.xy.com/custom-view/, is not present within the "widgets" folder. If the widget utilizes the "import()" function to dynamically load modules, it is necessary to deploy both the widget itself and the "chunks" folder within the "widgets" directory.
Could you please provide your thoughts on it, If I am missing anything.
Srikanth
