Dear Esri Developer Support,
I hope this message finds you well.
I am currently experiencing an issue when attempting to load a Portal instance from the following URL in a mobile application with admin credentials.
This issue occurs when using the ArcGIS Runtime SDK for Android version 100.15.7 — the portal fails to load successfully. However, when I revert to version 100.15.6, the portal loads without any issues and functions as expected.
This behavior suggests a possible regression or changes in version 100.15.7 affecting portal loading.
For your context, I am a Senior Engineer at Esri India, working on solutions that integrate closely with Enterprise Portals. I would appreciate your guidance on whether this is a known issue, and if there are any changes in portal handling in the newer SDK version that require adjustments in implementation.
Please let me know if you need additional details such as code snippets or logs.
Error message: "Unable to create instance of class com.esri.arcgisruntime.internal.io.b. Registering an InstanceCreator or a TypeAdapter for this type, or adding a no-args constructor may fix this problem."
Thank you for your support.
Best regards,
Ashish Mohan
Senior Engineer, EIC-ADM
Esri India
ashish.mohan@esri.in
