I am using ArcGIS Pro 3.5.2. I have created a COGO traverse text file. When I run it, it maps out the parcel correctly. When I hit the finish button, it reshapes and move the parcel. I have attached 2 screen snips:
1. COGO imported from the text file.
2. parcel outline after hitting finish button.
I have experienced this before, a lot actually, but so far when using the Import ArcMap Traverse File, I had not encountered it. Until today. The existing pink parcel uses the same starting point. Where I have experienced this before has been when using the same start point. Might be a clue or might be a red herring.
Anyone experienced this and have a solution? Thank you for your time.
Caitlin
