Here is my concern:
I created a form for a dairy inspection that has violations listed under topics. The user is able to tick a box that deducts points for violations resulting in a score. In the past this form has been published but:
After testing in the field the user needed 4 notice boxes added that will give the person inspected a Fix-it By 10 days, 72 hours, Immediately, and Do not use this product.
Initially I used a Select_multiple .csv in the media folder with the details of the Fix-It notice--however the text in the .csv is longer than 255 characters and I get an error. I decided to just put short references like: Ten day Notice in select multiple and let the long details of the Fix-It Notice be added later when a report is published.
The errors I am getting when trying to publish are attached.
I did go to our table in Pro to add the compliance field but it is not letting me save it in the table with that new field.
I am still working on getting the workflow down for adding/changing field to an already published survey.
Any help is appreciated. And yes, I do realize that I may be doing things in the wrong order.
I created the form first and then published to our enterprise system.
Thanks for any pointers.
