I'd like to have a comments field in Connect for each question so that I can tell what it's doing and why I put it there.
For example, I have a repeat in a group. The group's visibility is controlled by body::esri:visible, but the repeat is controlled with the same criteria with relevance. This is because I want the answers to be erased if the criteria changes.
I know this now, but there is absolutely no way I'm going to remember this in a few months.
The Label, Hint, and Guidance Hint columns are not appropriate for this because the user doesn't need to see these notes, and a notes question is not appropriate because then it's just cluttering up the survey.
Please add comments field.
Thanks!
