Is there a way to ensure that Column Headers use Names instead or Labels for the data? I have fields that utilize the same labels. This does not work well looking at the Data.
You can set the field alias manually using the bind::esri::FieldAlias Column, otherwise it will use the label in most cases
https://doc.arcgis.com/en/survey123/desktop/create-surveys/esricustomcolumns.htm#:~:text=2%2C147%2C483%2C648%20and%202%2C147%2C483%2C647.-,Field%20aliases,-By%20default%2C%20a
Fantastic. Thank you!
