I would like to know if either of the two options below area possible between ArcGIS Pro and MicroStation:
- Is it possible to get a map in .dgn or .dwg and convert it to become a map in ArcGIS pro (Layout Map) that I could add different shapefiles, change legend, etc.
or
- Is it possible to save a map from ArcGIS pro, and export it as .dgn or .dwg file?
If yes, I'd like instructions please.
I know it's possible to export shapefiles as dwg, and to import dgn/dwg into ArcGIS, but it comes as shapefiles only, even the map grids, text, scale bar, all as a feature in the map. I'd need to make that conversion with maps.
Thanks in advance!
