I am trying to create a 3D visualization of the recent flood here in Kerrville, TX. I was able to create a water surface elevation (WSE) raster from local DEMs and a depth raster but I had to split the WSE raster to get it to run successfully in the Create 3D Flood Level from Raster script provided by the solution. The problem is one section of the 3D poly/multipatch will be at the correct elevation and broken into many polygons, but the next section will be one large polygon and 100+ feet higher than the previous or next section.
I tried rerunning one of the incorrect sections and got the same results. I am going to try again with smaller sections but last time it took 28 hours to run the entire area.
Is there a trick to getting this tool to run correctly? Is this a bug in the script?
