Attribute table field name headings will not allow a font size smaller than 12?
Type in anything less than 12 and it changes to 12. Why? WAB 10 was perfect. Also note that changes the field name heading but not the text in the actual table for some reason.
Also when set to Use Layer settings it goes to alphabetical field name list which is not the layer settings. When set to customize it flips back to the what the layer is but when you load the app it flips it back again. We have way too many fields to reorder all of these. They must match our schema. Its always been layer order since the dawn of time. Where is alphabetical coming from?
On top of all of that Drawing result from View in Table action always goes back to alpha! No one wants alpha. We had a committee pick the field order and we cant change it.
thanks
