I am having trouble finding a PDF document showing all of the 2025 Tapestry Segmentation profiles. ESRI produced one for the 2024 segmentation profiles, but I don't see one for the 2025 update. I can download a pdf of a single profile if I run a "dominant tapestry profile" infographic in Business Analyst (attached), but I would like to download all of the profiles at once to save time. Does anyone know where I can find that file?
Upon further investigation (at the end of the article) it looks like you can download the PDF:
The help documentation includes PDFs of all segments:
Looking for the rundown on each Tapestry segment and LifeMode group? You can now access both high-level summaries and specific attributes directly from the dataset documentation. Start with the Introduction to LifeMode groups page, then choose a group to learn more about the segments within it.
Hey Sarah,
I appreciate your response. I looked at the links but they don't seem to provide the PDF's for each segment similar to the segment profiles provided in 2024. See this link to a pdf for 2024 1A Affluent Estates: Top Tier | Esri Tapestry Segmentation.
This is what I would like to download for each of the 60 segments from the 2025 update. Is it available?
Hi Josh,
Any luck locating these 4-page segmentation reports? I'm looking for them as well.Esri has published them for several years; it will be really disappointing if they discontinued them with the 2025 update.
I'm also unable to locate both the PDF's, and any further demographic information about the segments themselves. The documentation only lists LifeModes and is very bare bones. This makes the reports themselves useless.
Looks like the PDF was replaced by the ArcGIS Tapestry Segment Infographics Dashboard: https://links.esri.com/arcgis-tapestry-dashboard.
Here is the article that references the link: https://www.esri.com/arcgis-blog/products/esri-demographics/announcements/explore-arcgis-tapestry-segments-with-the-new-infographic-dashboard. Hope this helps.
I am looking for the Tapestry Zip Code lookup and cannot find it . When searching for it, the links go to the Tapestry Intro page. Can you help?
