Before I deploy our Water UN to production, I'd really like to understand what's needed to get isolation traces working. No matter what Tier I try (Water System, Pressure or Isolation), it always fails with "ERROR 001797: No valid subnetwork controllers found." Same thing happens even with the ESRI Foundation GDB (v 4.1) that I used as a starting point to build our UN.
It should be simple: System Valve / System is assigned "Isolating" Category, so all of those systems valves should act as barriers for such a trace if Filter Barrier is Category = Isolating, right?
I see the Subnetwork Controller for the Water Isolation Tier is System Valve / Isolation Zone (which I do have some in our system), but how does this relate to running isolation traces anywhere throughout the network?
@RobertKrisher wrote this: "You can always run an isolation trace by using a filter function barrier to define criteria for isolation." (https://community.esri.com/t5/arcgis-utility-network-questions/a-few-subnetwork-questions/m-p/1474082#M3893)
What does that mean? I tried adding this:
- Filter Barrier: Category = Isolating
- Filter Function Barrier: Count, Asset Group = 2
...but it still throws the same error message.
