I'm working on a task to inventory items on our open data site. So far, I've been able to get a list of items on the hub site. However, what I have not been able to get access to is the items "Scheduled Update" value under General Settings. In addition, I'd like to gather an items "Export Data" property as well. Screenshots are attached of the information I am attempting to gather through the item.
Hi @ShaunConwayCOL,
I don't see a direct way via the ArcGIS API for Python to access the Scheduled Update information but you can access via the requests module. See below.
from arcgis.gis import GIS import requests ## Access ArcGIS Online if using AGOL Notebooks agol = GIS("home") ## Access ArcGIS Online if using a standalone Python script #agol = GIS("AGOL_URL", "USERNAME", "PASSWORD") ## the Item ID for the content item item_id = "FS_ITEM_ID" ## return a token string token = agol._con.token ## set the URL url = f"https://hub.arcgis.com/api/download/v1/items/{item_id}/schedule?token={token}" ## get the response response = requests.get(url) ## print the json response print(response.json()) ##json response example ## scheduled for the 15th of each month at 6pm ## {'date': 15, 'hour': 18, 'itemId': '12345678910', 'cadence': 'monthly', 'timezone': 'Europe/Dublin'} ## if you get the following, the updates are Automated by Hub ## {'message': 'Scheduled updates for the item 12345678910 is not found.', 'error': 'Not Found', 'statusCode': 404}
For the additional "Export Data" property see below...
from arcgis.gis import GIS from arcgis.features import FeatureLayerCollection ## access ArcGIS Online agol = GIS("home") ## get the Feature Sevice as an Item object item = agol.content.get("FS_ITEM_ID") ## if the Item object type is Feature Service if item.type == "Feature Service": ## create a FLC object flc = FeatureLayerCollection.fromitem(item) ## print the current capabilities - if Extract in there then it is enabled print(flc.properties.capabilities) if "Extract" in flc.properties.capabilities: print("\tExtract Enaled") else: print("\tExtract Disabled")
I hope that helps. Please let us know if it works for you.
All the best,
Glen
Hi @ShaunConwayCOL, updated original response above,
