Thank you in advance for your help.
There should be a preview for the report that spits out a low resolution preview that doesn't consume credits.
You might have to change the way Survey123 collects and records the geopoint:
https://community.esri.com/t5/arcgis-survey123-questions/can-you-change-the-location-format-of-the-geopoint/td-p/779664
Otherwise here is some reference material, doesn't specifically answer your question but helps with syntax: https://doc.arcgis.com/en/survey123/browser/analyze-results/featurereport-map.htm
There is additional information here regarding pulling data, specifically coordinates. It has different formatting then you provided. I will try exporting different ways and run sample reports to save credit https://community.esri.com/t5/arcgis-survey123-questions/can-pulldata-geopoint-pull-lat-long-in-dms/td-p/1280222#:~:text=Hi%2C%20does%20anyone%20know%20if,Go%20to%20Solution.&text=Hello%20@NatalieSlayden%2C,want%20to%20separate%20the%20calculations.
Either way I think handling the conversion in the form is the way to go! I like what you found in that you can display in the form different than the report if that is important.
