We are migrating our on-prem SQL windows server to Microsoft Azure and have been testing Azure SQL Database as a PaaS alternative to a windows server deployment method. Our organsiation uses Microsoft EntraID using MFA as the required method to connect to sevices such as our SQL databases however have been struggling to get this method working using azure sql database. We have successfuly so far::
- deployed an sql database through the azure poral
- enabled the entreprise geodatbase through ArcGIS Pro (3.4.3) - (Note: ODBC 17 drivers are installed)
- connected to the database using the standard database authenticiation method (gisowner, pword).
- created a user role group
- using SQL Server Managemnt Studio 20 added an Entra user to the database using their MFA and added them to a user group. They can successfully connected to the database directly though SSMS.
When we try to connect to the azure SQL database through ArcGIS Pro using Microsoft EntraMFA method however we are recieving a 'bad login user' message. We recive the same error message on all Entra authoenticiation menthods.
Is there any advice / documentation / help that could be provided as to how/ if it's possible to connect to an azure SQL database using our Entra a/c using MFA?
Many Thanks in advance
Philip
