I republished a survey using Connect and added an integer field within a repeat. When that question is populated with a value, the resulting value is '0' in the related table. Any ideas why this is?
I republished the survey and this seemed to take care of the issue. Not sure why this was occurring the first time around.
Can you share your xlsx form? It is doing something if you're getting a 0 because otherwise it would be empty unless you had a default value set.
