When I add an acount(not sde) with sde schema to a geodatabase, the sde account of other geodatabase can not access geodatabase. With error info :
Underlying DBMS error, exception has occured,
Failed to connect to the specified DBMS instance.
A database connection exception has occurred.C Underlying DBMS error[42000:[Microsoft][ODBC Driver 17 for SOL Serverl[SQL Server]The SELECT permission was denied on the object "'SDE_version',database swyGDB, schema sde No extended error].
