I'm working with @ArcGIS/core@4.21.2 in a Vue application and facing some performance challenges when trying to display a large dataset on a map.
We’ve uploaded a CSV file with around 15 million rows into a hosted feature layer. When applying a filter, the resulting dataset includes approximately 350,000 points. However, the data is being fetched in batches, and seems to be limited by a maxRecordCount setting. Even though I attempted to update this setting using the ArcGIS updateDefinition API (as described here: https://developers.arcgis.com/rest/services-reference/online/update-definition-feature-service-.htm), the value still shows as 1000, and the actual requests seem capped at 4000 records.
In some cases, even fetching 4000 records takes up to 2 minutes, possibly due to how offset-based pagination is handled.
Given this situation:
What is the best approach for efficiently displaying such large datasets on the map?
Would it be better to use techniques like tiling, generalization, or server-side clustering?
Any recommendations or best practices would be greatly appreciated.
