Hi - I'm working with Javascript maps SDK 4.32 and am attempting to add a feature layer to a map component. I'm basing my effort on the map component angular sample on github (https://github.com/Esri/jsapi-resources/tree/main/component-samples/map-components/samples/angular) and this post about adding a feature layer to a map component (https://community.esri.com/t5/arcgis-javascript-maps-sdk-questions/map-component-api/td-p/1418711)
Below is the code I'm using. I'm getting an error 'addLayer does not exist on type element'
html:
<arcgis-map item-id="d5dda743788a4b0688fe48f43ae7beb9" (arcgisViewReadyChange)="arcgisViewReadyChange($event)"></arcgis-map>
component:
import { Component, CUSTOM_ELEMENTS_SCHEMA } from '@angular/core';
import "@arcgis/map-components/components/arcgis-map";
import FeatureLayer from '@arcgis/core/layers/FeatureLayer';
Component({
selector: 'app-rd-map2',
imports: [],
templateUrl: './rd-map2.component.html',
styleUrl: './rd-map2.component.css',
schemas: [CUSTOM_ELEMENTS_SCHEMA]
export class RdMap2Component {
arcgisMap = document.querySelector("arcgis-map");
featureLayer = new FeatureLayer({
url:
ngOnInit() {
var a = this;
a.arcgisMap.addEventListener("arcgisViewReadyChange", () => {
a.arcgisMap.addLayer(this.featureLayer);//==> error occurs here addLayer does not exist on type element
any ideas how to get a reference to the map component so the feature layer can be added?
Pete
