Andrew,
Yes Using WAB Developer edition will give you the ability to customize code and do exactly what you are after.
I see https://community.esri.com/message/705716-passing-xy-coordinates-in-agol-or-agol-wab-to-outlink-url is a dupe of this conversation. Probably is best to have it as a new conversation, but if Robert (who would be the expert) answers is here, you might just want to delete the other....or include a link to the answer here and mark "assumed answered"
just an fyi, lots of good tips (including in comments) on posting to geonet https://community.esri.com/community/help-and-feedback/blog/2016/08/15/community-news-and-tips-how-to-ask-questions-and-get-answers?sr=search&searchId=8e834fa5-8913-4cb0-8afd-6c872b1ff1d0&searchIndex=0
But using the WAB (not AGOL) I could likely have some event listener to accomplish something of this sort, right? Any insight there?
Unfortunately in AGOL WAB you do not have access to modify code that would allow you to develop the portion to add a popup link that would append the coordinates to the url of a link. WAB by default does have a center url parameter though:
http://doc.arcgis.com/en/web-appbuilder/manage-apps/app-url-parameters.htm#ESRI_SECTION1_DFA518B2DF5945EFB77D1C925DA2CF76
Is there a way to accomplish this in AGOL (or AGOL WAB)? The framework is pretty robust...
I want to basically have a user click on a point and the app stores that click's coordinates. Then in the pop-up, there is an out-link <a href></a> that appends the x & y to the end of the URL.
So if a user clicked a point of 100,30 the outlink URL would be http://website.com/index.html?x=100&y=30
Is this possible?
khutchins-esristaff
I know this post is going on 3 years old, but thank you! This code works perfectly!
function gup(name) { name = name.replace(/[\[]/, "\\\[").replace(/[\]]/, "\\\]"); var regexS = "[\\?&]" + name + "=([^&#]*)"; var regex = new RegExp(regexS); var results = regex.exec(window.location.href); if (results == null) return ""; else return results[1]; }
//check to see if an envelope has been sent (ie four values in x1,x2,y1 & y20 var newExtent = new esri.geometry.Extent(); var xMin = Math.abs(gup('x1')); var yMin = Math.abs(gup('y1')); var xMax = Math.abs(gup('x2')); var yMax = Math.abs(gup('y2')); var mk, pt, gra; //check to see if just a point has been sent in x1 & y1 if (Math.abs(gup('y2')) == 0 && (Math.abs(gup('x2')) == 0) && (Math.abs(gup('x1')) > 0) && (Math.abs(gup('y1')) > 0)) { x1 = xMin y1 = yMin xMin = xMin - 50 yMin = yMin - 50 xMax = xMin + 100 yMax = yMin + 100 dojo.connect(map, "onLoad", function () { ShowLocation(x1, y1); }); } if ((xMin > 0) && (yMin > 0) && (xMax > 0) && (yMax > 0)) { newExtent.xmin = xMin; newExtent.ymin = yMin; newExtent.xmax = xMax; newExtent.ymax = yMax; newExtent.spatialReference = new esri.SpatialReference({ wkid: 27700 }); map.setExtent(newExtent); }
var urlObject = esri.urlToObject(document.location.href); // Set our default position, zoom level and layerid's x = 349299; y = 313074; zoomLevel = 0; // Do we have a qeury string on the URL? if (urlObject.query) { // Do we have a coords parameter? if (urlObject.query.coords) { var coords = urlObject.query.coords.split(','); // We have an x and a y right? if (coords.length == 2) { x = parseFloat(coords[0]); y = parseFloat(coords[1]); console.log("x coord passed to map: ", x); console.log("y coord passed to map: ", y); } } // Let's check for a zoomlevel if (urlObject.query.zoomLevel) { var zoomLevel = parseInt(urlObject.query.zoomLevel); console.log("Zoomlevel passed to map: ", zoomLevel); } //Let's check if any layers are specified /*if (urlObject.query.layers) { //layers = parseInt(urlObject.query.layers); layers = urlObject.query.layers.split(','); console.log("layer ID's passed to map: ", layers); }*/ if (urlObject.query.lgsl) { var lklgsl = urlObject.query.lgsl; layers = matchLgsl(lklgsl); console.log("lgsl code:", lklgsl); } //set the visable layers that where passed in the url lbsr.setVisibleLayers(layers); console.log("Layer ID's being drawn", layers); } // Position our mapto the x and y provided in the url var point = new esri.geometry.Point([x, y], new esri.SpatialReference({ wkid: 27700 })); //var point = esri.geometry.Point(new esri.geometry.Point(x, y)); console.log("Zooming to location...", point, zoomLevel); map.centerAndZoom(point, zoomLevel); console.log("Zoom complete"); // Highlight the item on our map if (!graphic) { addGraphic(point); } else { graphic.setGeometry(point); };
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Topographic Map</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dijit/themes/claro/claro.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } .esriScalebar{ padding: 20px 20px; } #map{ padding:0; } </style> <script type="text/javascript">var djConfig = {parseOnLoad: true};</script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.1"></script> <script type="text/javascript"> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); var map; function init() { var initExtent = new esri.geometry.Extent({"xmin":-122.46,"ymin":37.73,"xmax":-122.36,"ymax":37.77,"spatialReference":{"wkid":4326}}); map = new esri.Map("map",{ extent:esri.geometry.geographicToWebMercator(initExtent) }); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); map.addLayer(basemap); //if there are url params zoom to location var coords, zoomLevel; var urlObject = esri.urlToObject(document.location.href); if(urlObject.query && urlObject.query.coords && urlObject.query.zoomLevel){ var coords = urlObject.query.coords.split(','); var lon = parseFloat(coords[0]); var lat = parseFloat(coords[1]); var zoomLevel = parseInt(urlObject.query.zoomLevel); var point = esri.geometry.geographicToWebMercator(new esri.geometry.Point(lon,lat)); map.centerAndZoom(point,zoomLevel); } dojo.connect(map, 'onLoad', function(theMap) { //resize the map when the browser resizes dojo.connect(dijit.byId('map'), 'resize', map,map.resize); }); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="border:1px solid #000;padding:0;"> </div> </div> </body> </html>
