I'm building a javascript/Typescript/Angular application to view digital elevation model (DEM) data. The source data are Cloud-Optimized Geotiffs (COGs), which are brought in as an ImageryTileLayer with a RasterStretchRenderer.
To render them, I want users to have the following color ramp controls:
- DynamicRangeAdjustment: On/Off (hold)
- Set minimum/maximum values manually [this is working]
- Use min/max values from entire raster [this is working]
I think it would be useful to have a way to put a hold on the dynamicRangeAdjustment so that, when turned off, it would preserve the current color ramp settings. However, I can't seem to find where those min/max values are being computed or stored.
Suppose the min/max of the overall dataset is 150.512 m and 401.768 m. These values are accessible via the layer.serviceRasterInfo.statistics[0] object. The renderer.customStatistics[0] object is also usable when I want to set a manual min/max (e.g. 250 m and 310 m). I can toggle the DynamicRangeAdjustment on, which then works normally. When DynamicRangeAdjustment is turned off, though, it reverts to the dataset min/max (or, if I set it, my custom min/max). I'm looking for a way to pull the current values for min/max that DynamicRangeAdjustment is working with, which I will then feed into the custom min/max. Is that possible, and if so, how?
