Is there a way to use the field alias in Bar Charts?
@Wei_Ying developer edition
Hi @C_McNamara ,
Which environment are you using? If sorting by category didn't line up correctly it looks like a bug.Can you provide more details? Thank you!
Turns out I can use the field alias. I had to republish with the correct alias but I still can't get the categories to line up as intended for an age pyramid. I will need to change the actual field name and make it alphabetical in the correct order i need for the chart.
