Hi there,
in a Custom Widget, I want to use the reduxStore to hold some features, such that I can access them in every component without having to prop drill. With simple values like strings, this works marvelous. How ever if I try it with an esri.Graphic Object, i get an immutable object back, which has different properties. What is the correct way to store such values in the redux store? Thanks
useEffect(() => {
if (!appStore.getState().widgetsState?.[id]?.steps) {
appStore.dispatch(appActions.widgetStatePropChange(id, 'steps', Search));}}, [id]);
//and retrieving:
const steps = appStore.getState().widgetsState?.[id]?.steps;
//this works as expected.
//However
queryFeatureLayer(query).then((feat: Graphic) => {
appStore.dispatch(appActions.widgetStatePropChange(widgetId, '_lineFeature', feat));
appStore.getState().widgetsState["widget_3"]._lineFeature yiels
Object { … }
__immutable_invariants_hold: true
asMutable: function B(e)
getIn: function F(e, t)
merge: function A(e, t)
replace: function P(e, t)
set: function N(e, t, r)
setIn: function L(e, t, r)
update: function M(e, t)
updateIn: function U(e, t)
without: function E(e)
<prototype>: Object { … }
// which has no similaritys to a __esri.Graphic Object
