Hello everyone,
I'm experiencing an issue with the 'Asset Package to Geodatabase' tool while transferring data from the Asset Package to the Utility Network. Specifically, the tool works fine when running without the D_RENAME table, but it fails when we choose the option to translate assets using the D_RENAME table, even though the table itself is correct.
I’d like to ask if anyone else has encountered this issue or if it could be a bug in version 3.4 of ArcGIS Pro. I also want to point out that the same tool works correctly in ArcGIS Pro version 3.3.2, even with the D_RENAME table used for asset translation.
Mariano
