Hello,I'm really new to ArcGIS for Silverlight.I'm trying to create map that contains a base map, a polygon layer and a point layer. And i want to identify the point features.I can see the layers. But whenever i click on the points, i get this error message:[ATTACH=CONFIG]22594[/ATTACH]Here is the mainpage.xaml:xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" xmlns:esri="http://schemas.esri.com/arcgis/client/2009" xmlns:slData="clr-namespace:System.Windows.Controls;assembly=System.Windows.Controls.Data" xmlns:i="http://schemas.microsoft.com/expression/2010/interactivity" mc:Ignorable="d" d:DesignHeight="300" d:DesignWidth="400"> <Grid x:Name="LayoutRoot" Background="White" > <Grid.Resources> <esri:PictureMarkerSymbol x:Key="DefaultPictureSymbol" OffsetX="35" OffsetY="35" Source="/Assets/images/i_about.png" /> <esri:SimpleRenderer x:Key="MySimplePolygonRenderer"> <esri:SimpleRenderer.Symbol> <esri:SimpleFillSymbol Fill="Green"> </esri:SimpleFillSymbol> </esri:SimpleRenderer.Symbol> </esri:SimpleRenderer> <esri:SimpleRenderer x:Key="MySimplePolylineRenderer"> <esri:SimpleRenderer.Symbol> <esri:SimpleLineSymbol Color="Red"> </esri:SimpleLineSymbol> </esri:SimpleRenderer.Symbol> </esri:SimpleRenderer> <esri:SimpleRenderer x:Key="MySimpleMarker"> <esri:SimpleRenderer.Symbol> <esri:SimpleMarkerSymbol Color="Red" Style="Circle"></esri:SimpleMarkerSymbol> </esri:SimpleRenderer.Symbol> </esri:SimpleRenderer> </Grid.Resources> <esri:Map x:Name="MyMap" WrapAround="True" Background="White" Extent="406252.2726,4543357.5695,407437.2354,4544741.7271" MouseClick="QueryPoint_MouseClick" > <esri:ArcGISDynamicMapServiceLayer ID="Uydu2011" Url="http://ibbmaps.ibb.gov.tr/maps/rest/services/Uydu_2011_ED50/MapServer"/> <esri:FeatureLayer ID="Binalar" Url="http://services1.arcgis.com/woiXiLpMPLtJh7WJ/arcgis/rest/services/binalar/FeatureServer/0" Renderer="{StaticResource MySimplePolygonRenderer}"/> <esri:FeatureLayer ID="Noktalar" Url="http://services1.arcgis.com/woiXiLpMPLtJh7WJ/arcgis/rest/services/noktalar/FeatureServer/0" Renderer="{StaticResource MySimpleMarker}"/> <esri:GraphicsLayer ID="MyGraphicsLayer" /> </esri:Map> <Border x:Name="IdentifyBorder" Background="#77919191" BorderThickness="1" CornerRadius="5" HorizontalAlignment="Right" BorderBrush="Gray" VerticalAlignment="Top" Margin="5"> <Border.Effect> <DropShadowEffect/> </Border.Effect> <Grid x:Name="IdentifyGrid" HorizontalAlignment="Right" VerticalAlignment="Top" > <Grid.RowDefinitions> <RowDefinition Height="30" /> <RowDefinition Height="*" /> </Grid.RowDefinitions> <TextBlock x:Name="DataDisplayTitleBottom" Text="?lçe Sorgulamak ?çin Haritaya T?klay?n?z" Foreground="White" FontSize="10" Grid.Row="0" Margin="15,5,15,1" HorizontalAlignment="Center" > <TextBlock.Effect> <DropShadowEffect /> </TextBlock.Effect> </TextBlock> <Grid x:Name="IdentifyResultsPanel" Margin="5,1,5,5" HorizontalAlignment="Center" VerticalAlignment="Top" Visibility="Collapsed" Grid.Row="1"> <Grid.RowDefinitions> <RowDefinition Height="30" /> <RowDefinition Height="*" /> </Grid.RowDefinitions> <ComboBox x:Name="IdentifyComboBox" SelectionChanged="cb_SelectionChanged" Margin="5,1,5,5" Grid.Row="0"> </ComboBox> <ScrollViewer HorizontalScrollBarVisibility="Hidden" VerticalScrollBarVisibility="Auto" Width="230" MinHeight="200" Grid.Row="1"> <slData:DataGrid x:Name="IdentifyDetailsDataGrid" AutoGenerateColumns="False" HeadersVisibility="None" Background="White"> <slData:DataGrid.Columns> <slData:DataGridTextColumn Binding="{Binding Path=Key}" FontWeight="Bold"/> <slData:DataGridTextColumn Binding="{Binding Path=Value}"/> </slData:DataGrid.Columns> </slData:DataGrid> </ScrollViewer> </Grid> </Grid> </Border> <Border Background="#77919191" BorderThickness="1" CornerRadius="5" HorizontalAlignment="Left" VerticalAlignment="Top" Margin="20" Padding="5" BorderBrush="Black" > <ListBox x:Name="MyList" ItemsSource="{Binding ElementName=MyMap, Path=Layers}"> <ListBox.ItemTemplate> <DataTemplate> <StackPanel Orientation="Horizontal"> <!--Layer visibility checkbox--> <CheckBox IsChecked="{Binding Visible, Mode=TwoWay}" /> <!--Opacity slider--> <Slider Margin="-5,0,0,0" Minimum="0" Maximum="1" Width="30" Value="{Binding Opacity, Mode=TwoWay}" Height="18" /> <!--Layer name--> <TextBlock Text="{Binding ID, Mode=OneWay}" Margin="5,0,0,0" > <!-- Tooltip on hover--> <ToolTipService.ToolTip> <StackPanel MaxWidth="400"> <TextBlock FontWeight="Bold" Text="{Binding CopyrightText}" TextWrapping="Wrap" /> <TextBlock Text="{Binding Description}" TextWrapping="Wrap" /> </StackPanel> </ToolTipService.ToolTip> </TextBlock> </StackPanel> </DataTemplate> </ListBox.ItemTemplate> </ListBox> </Border> </Grid> </UserControl>
