I have a standalone table in an Enterprise 11.3 sde geodatabase. I've published this to our Portal as a hosted feature layer and created a survey from this. The problem I'm running into is that survey submissions are only showing up in the S123 dashboard, not in the hosted feature layer or the sde table. I've enabled editing, global IDs, sync and editor tracking and the problem persists. I was having trouble setting up sync because of Time Only, Date Only and Timestamp Offset fields, but that doesn't seem to be the issue. Unless it is?
