ArcMap had the functionality to select a Stop and press 1 on the keyboard to flash its location on the Network Street Layer. I cannot find this on ArcGIS Pro.For multiple stops on a parcel (such as a Mobile Home Park without Network streets) and located near various Streets and Highways, it is easier to use the driveway for the single Network location for all stops. Showing which stops are on the wrong street is easy with the Flash tool. When a stop is located too far back from the street, the solution may involve a 30 minute round trip along the interstate to get to the Network Location. It's easier to drag the stop to the local street and Flash to verify the stop is located on the correct network street.
Yes, unfortunately, this feature does not exist in Pro.
The best you can do is run the XY Table To Point tool using the SnapX and SnapY fields from the network analysis layer sublayer you're looking at (like Route Stops). This will create a separate feature class showing the network locations of each original point.
You an also use the Snap To Network option on the Add Locations tool when adding your input locations to the network analysis layer's sublayer. This will move them from their original location to the network location, with optionally some offset.
