I developed an App using the Interactive Legend Instant App and I haven't changed anything with the map but now when I open it the legend just spins, it never loads.
Thanks for this information. It started when I submitted the post, and it had always worked up until then. As a work around, I reduced the number of layers that were visible when the app first opened, and therefore the number of layers the legend needed to load. This has fixed the problem sufficiently enough for my use.
Hi @SusieDFG I checked some of my own existing Interactive Legend apps and am not seeing the issue. Do you know when this started or the last time it worked and are you able to share the link to your app? Also if possible an Esri Support case would be beneficial to investigate deeper. https://support.esri.com/en-us/contact
