Regarding this post: https://www.esri.com/arcgis-blog/products/js-api-arcgis/developers/javascript-maps-sdk-a-full-transition-to-components/
How will this affect custom ExB widget development? Is Esri updating the Jimu framework to accommodate these, or is it up to the user?
The component is more modern and intuitive for developers, so I think it's the right choice.
And we must consider that the widgets will be depracated in 2026Q1 and removed in 2027Q1.
Let's take Sketch for example.
import Sketch from "@arcgis/core/widgets/Sketch"; const sketchWidget = new Sketch({ view: jimuMapView.view, layer: graphicsLayer, .... etc ...
<arcgis-map basemap="topo-vector" center="139.5716,35.696" zoom="18"> <arcgis-sketch position="top-right" creation-mode="update"> </arcgis-sketch> </arcgis-map>
The main change in Maps SDK is to separate the UI widgets from the core logic without UI.
The new widgets' underlying technology is https://developer.mozilla.org/en-US/docs/Web/API/Web_components
These changes do not affect the Jimu framework; instead, they require adaptive modifications by the ExB widgets that rely on Maps SDK widgets, such as Map, Measurement, Table, and Edit.
