I am investigating the use of ArcGIS to generate obstacle limitation surfaces for aerodromes in Australia. I have used the OIS tool to ensure the parameters match the Australian MOS139 standards but have noticed there is no option to adjust the outer horizontal surface, only the Horizontal Surface which seems to be the inner horizontal.
Unified Facilities Criteria seems to have the option but not Annex 14 Precision approaches.
Also, is there a way to convert the generated surfaces in to z valued poly lines?
Thanks!
