I want to improve the time it takes to load an entire project even when I just want to make a small edit.
It would be convenient if I could open only a specific map and its related data source and layout from a project that contains multiple maps and layouts, and edit or output it.
It would be even better if I could easily switch between them with a simple operation (such as holding down the shift key while opening a project, and applying the function).
For example,
In a city project, there are maps "Population", "Industry", and "Transportation", and layouts "A3" and "A0".
I want to open layout "A3" with map "Population" applied, edit it, and output the image.
However, map "Industry" contains data for a wide range of topographical maps, so it takes a long time to open the project.
In such cases, I would like to be able to select and load only map "Population" and layout "A3", open them, and edit them smoothly.
This is a simple image. Thank you for reading my idea.
