I am looking to see if there a way to create a buffer around a bunch of point features, but to eliminate gaps within the buffer. Essentially, I need to quantitatively draw a boundary around the grouping of points to create a site. Using the existing buffer tools, you can dissolve into a single buffer feature, but there are still gaps in the buffer. I know that I could make the buffer large enough to cover the extent of the point group, however, then my site would be massively inflated. I would manually draw my buffer around the points, but this is also not an option as I need to be able to explain statistically, how the buffer was generated.
I appreciate any and all help!
