We would like to use the export of the report in XML format for our quality documents. However, I can't get the XML file to be readable. In Notepad++, I see a lot of code and lose the nice layout. Are there other options?
beyond just taking a screengrab, maybe you want to support this idea
ArcGIS Pro 3.0.2: An option to export the model bu... - Esri Community
You could also post a xml excerpt on stack overflow and ask why notepad++ can't format it. Or ask the creators of notepad++.
I wonder if a free online xml formatting site could do it, as long as there isn't any sensitive info in the xml.
Thanks for the message and help! I've supported the idea. I'm still looking into how to take a screenshot of a scrolling screen. ShareX is not accepted here, and Greenshot can't do it. I'll continue searching.
In Pro, I have an export option to XML, but unfortunately not to PDF. Is there a way to read the XML in such a way that I can print it to a PDF? There is also an export to SVG, but then I lose all detailed information.
your 2nd line is indicating that a "svg" scaleable vector graphic, representation is being represented in json format. Notepad++ can only show text not graphics.
Do you have an option to export to pdf?
