What should the structure of the new GeoEvent Definition for the JSON data be to read the subsequent JSON data? There is an array in the data, which I cannot get into the GeoEvent definition.
URL to the data stream
https://www.pegelonline.wsv.de/webservices/rest-api/v2/stations.json?waters=POTSDAMER%20HAVEL,POTSDAM&includeTimeseries=true&includeCurrentMeasurement=true
The data is structured as follows:
"uuid": "5e10e1e7-9115-4bd7-ad57-e2062f516891",
"number": "580412",
"shortname": "POTSDAM",
"longname": "POTSDAM",
"km": 26.63,
"agency": "STANDORT BRANDENBURG",
"longitude": 13.072071020002,
"latitude": 52.3998866995299,
"water": {
"shortname": "PHv",
"longname": "POTSDAMER HAVEL"
"timeseries": [
"shortname": "W",
"longname": "WASSERSTAND ROHDATEN",
"unit": "cm",
"equidistance": 15,
"currentMeasurement": {
"timestamp": "2025-01-28T15:15:00+01:00",
"value": 102,
"stateMnwMhw": "normal",
"stateNswHsw": "unknown"
"gaugeZero": {
"unit": "m. ü. NHN",
"value": 28.434,
"validFrom": "2019-11-01"
"shortname": "WT",
"longname": "WASSERTEMPERATUR ROHDATEN",
"unit": "°C",
"equidistance": 60,
"timestamp": "2025-01-28T15:00:00+01:00",
"value": 4
"shortname": "LT",
"longname": "LUFTTEMPERATUR ROHDATEN",
"unit": "°C",
"equidistance": 15,
"value": 7.6
The output from the input processor currently looks like this:
"GED_Name": "potsdam_input",
"number": "580412",
"km": 26.63,
"longitude": 13.072071020001967,
"water": "water : PHv,POTSDAMER HAVEL",
"timeseries": "[timeseries : W,WASSERSTAND ROHDATEN,cm,15.0,currentMeasurement : 2025-01-28T15:15:00,102.0,normal,unknown,gaugeZero : m. ü. NHN,28.434,2019-11-01, timeseries : WT,WASSERTEMPERATUR ROHDATEN,°C,60.0,currentMeasurement : 2025-01-28T15:00:00,4.0,null,null,null, timeseries : LT,LUFTTEMPERATUR ROHDATEN,°C,15.0,currentMeasurement : 2025-01-28T15:15:00,7.4,null,null,null]"
If I feed this into a fieldmapper, I get this output:
"GED_Name": "potsdam_output",
"number": "580412",
"km": 26.63,
"water_shortname": "PHv",
"water_longname": "POTSDAMER HAVEL",
"timeseries_shortname": "null",
"timesseries_longname": "null",
"timeseries_unit": "null",
"timeseries_equidistance": "null"
I can process the data stream fine up to the array "timeseries", but I can't get the array to work. Can someone help me define the input or output GeoEvent definition for the array?
Nico
