When executing the Generate Lights Sector tool (with usable LIGHTS data in AidsToNavigationP) the error
Failed to open table LightSectorsL!
is thrown.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/maritime/generate-light-sector.htm
and https://pro.arcgis.com/en/pro-app/latest/tool-reference/maritime/generate-light-sector.htm
describe that such table should be present in the feature dataset so the tool can write to it.
However, there does not seem to be such feature class imported in the workspace when using any of the XML Workspace Documents provided in the product files for 3.4. Manually adding one in the workspace does not seem to resolve the issue (possibly because the schema is not correct when adding without any additional fields).
Thus, I'm looking for the schema for this feature class so it can be added manually, OR an example feature class that can be copied OR a XML Workspace Document that would include LightSectorsL.
Thank you!
