Good morning,
Is there a way to load "Predefines Unique Values". I am currently entering them manually.
Hi @SanchezNuñez
Can you be more specific on the widget you are trying to use?
I have included a link to another community post which you might find helpful
Solved: Query widget - unique values - Esri Community
Sure @DanielFox1 ,
in a Select, Query or Filter widget when configuring the selection with the button SQL Expression, it opens a window called "SQL Expression Builder", then there is a way to Predefine Unique Values for a field. I have to enter them manually. I am looking for a way to upload them, because I use this same search values in other widgets.
Thank you for pointing this out. ExB does not currently support this feature. We will look into this feature further to see if it can be enhanced.
Ke
Excellent @Ke_Xu !!
@Ke_Xu any updates on this? After I've been typing in a list over and over and over whenever I have to move my clauses around, I would really like to just load the values. Please. Thank you.
