lyt.exportToPDF(os.path.join(param1,outname),"ALL","",multiple_files,resolution=param5,output_as_image=True)
I have a tool that exports selected layouts. I thought I would add an option to select 'Output as Image' which greatly reduces output file size. It has the opposite effect, though. It vastly increases file size - almost 10 times. From 1.9 to about 13 mb. I exported using layout->share, selected output as image and the output was reduced in size as expected. Is there anything about using the setting in a script tool I should know?
The above script line works fine and the variables (param1, param5, etc...) are working as desired. Adding 'output_as_image=True' just has the opposite effect of what I hoped. 'output_as_image=False' works as I would expect .
Thank you for any information you may be able to provide.
Randy McGregor
