I’m having an issue with ArcGIS Pro where every time I create a line using the "Create" tool and finish it, the line disappears. The only way to make the line reappear is to hit "Save" from the Edit tab and refresh the program. However, this workaround is not ideal, as my workflow requires the lines to be visible in real-time as I draw them.
I’ve tested creating lines in the same file on a different computer, and everything works fine. The issue only happens on this specific computer.
Has anyone experienced something similar or knows a solution to fix this issue? Any help would be greatly appreciated!
