I have custom geoprocessing services which I am bringing into the Analysis widget. The Analysis widget will simply select all the features on a layer, so since I need to allow users to select specific features from a layer as input for the geoprocessing services, I am using the Select widget.
Is there a way to make sure only a specific layer is used as input for a parameter?
For example if it is a geoprocessing service that transfers polygons from "Positions" to another layer, is there a way to make sure only selections from the "Positions" layer can be used for a certain parameter?
