Is there a basemap that exists for the map viewer that contains the street direction (one way streets), like there is on google maps?
Sorry if the info exists, I was not able to find anything.
Thanks!
Hey @mikaël, we noticed that the Esri hosted OSM basemaps don't include the one-way direction arrows (even though the information is available in OSM). What we did was:
It's not ideal because the directional markers have to be updated separately so could get out of sync with the basemap but it was the best we could do. I note that Esri have stopped updating the OSM basemaps now too, so maybe in the new Overture based basemaps will include the directional markers (we can but hope).
Hope this helps.
Try Open StreetMaps roads layer. Here is a link to one that Esri hosts : https://arcg.is/0SPPSK0
If you want to connect to the data directly try Overture maps or OpenStreetMap where oneway is a field: https://www.openstreetmap.org/
Thanks for the suggestion.
I played with the feature layer a bit and there is an "oneway" field. But the table is so huge (53M rows), that it basically fails when I try to filter it or cut/join the data to just retain data for my work area.
Also, there are no arrow symbols on the , so I'm not sure how I would map the "oneway" field, I'd have to try if I could get it to work.
That seems like a good enough workaround.
Thank you!
