ArcGIS Online was just updated (November 2024). Learn what's new by reading the following resources:
Learn more in the What’s New Documentation and watch the What’s New Video to see these capabilities in action.
Subscribe to our newsletter or join the Esri GIS LinkedIn group to get the latest ArcGIS Online news. We’d love to hear about your work! Share with us how your organization is using ArcGIS Online.
Visibility icons in the table of contents are missing on all 3D Viewer Instant apps since the update.
@BrookeChan After this last ArcGIS Online update my edit widget stopped working properly in all my Organization's Experience builder apps. I can no longer edit geometry of an existing feature. I get an error each time. The only fix that I tested and that actually works is to re-create the experience using a new template. I can't spend a few weeks doing that. Any advice? Thanks!
Well, I did spend a few weeks fixing the broken edit widgets. I removed the broken widget then added a new edit widget and re-configured to the original custom specifications I need for each web application. Seems like the default for the edit widget was switched from no layers selected to all layers selected by default. Now you have to uncheck every single layer one by one instead of selecting a few layers you want editable.
Update: All of my edit widgets are broken again. I don't understand what ESRI did to keep breaking this but it's incredibly frustrating when other people can't do their jobs and I have to somehow come up with another solution and manually fix 50+ web apps to keep things going. While writing this I realized if I customize the editable fields list that's when the widget breaks. If I keep the defaults it works fine. Unfortunately that doesn't work for me. Please somebody chime in if you can. Any advice @Jianxia ?
Here's my latest fix to this problem. Since the "Customize" option is broken now I have to use the "Use webmap settings". In order to get this to work similarly to customize I had to open the web map, click on the layer I want to be editable, then create a form and drag/drop the selected fields I want to be editable. Work through each layer one by one then save the web map. Now it works using the Edit widget in Experience Builder AND honors the Capability settings as seen in the above snapshot.
