Hello -
I am working in ArcGIS Dashboards and have a data expression that is no longer working after the update last night. I am getting this error "Test execution error: layerId=1 provided for Map Service item. Verify test data." It is not clear what this error is - the layerid is correct. I am using a map image service pulled in from Enterprise Portal that has 3 layers. See my code below.
var port = Portal('https://www.arcgis.com');
var fs = filter(FeatureSetByPortalItem(
port,'xxxxxxxxxxxxxxxx', 1,
['PH_PROJECTID', 'PH_PHASEID', 'PH_PHASENAME', 'PH_COMPLDATE', 'PH_STATUS', 'PH_PHASETYPE', 'PH_STREAMRESTORED_LFT', 'PH_WETLAND_AC', 'PH_FLOODPLAIN_AC', 'PH_CULVERTREPAIRED_FT', 'PH_SEDIMENTREMOVED_CY', 'PH_BASINSTORAGE_ACFT', 'PH_TREESPLANTED', 'PH_WAC', 'PH_SUBWATERSHED', 'PH_COMMUNITY1'],
false),
"PH_STATUS='07. Completed' AND (PH_PHASETYPE='1. DesCon' OR PH_PHASETYPE='2. SWIM' OR PH_PHASETYPE='3. Partner' OR PH_PHASETYPE='4. Parcel Acquisition')"
var out_dict = {
fields: [
{name: 'projectid', type: 'esriFieldTypeString'},
{name: 'phaseid', type: 'esriFieldTypeString'},
{name: 'phasename', type: 'esriFieldTypeString'},
{name: 'phasetype', type: 'esriFieldTypeString'},
{name: 'complyear', type: 'esriFieldTypeString'},
{name: 'status', type: 'esriFieldTypeString'},
{name: 'stream', type: 'esriFieldTypeDouble'},
{name: 'wetland', type: 'esriFieldTypeDouble'},
{name: 'floodplain', type: 'esriFieldTypeDouble'},
{name: 'culvert', type: 'esriFieldTypeDouble'},
{name: 'sediment', type: 'esriFieldTypeDouble'},
{name: 'basin', type: 'esriFieldTypeDouble'},
{name: 'trees', type: 'esriFieldTypeInteger'},
{name: 'wac', type: 'esriFieldTypeString'},
{name: 'subwatershed', type: 'esriFieldTypeString'},
{name: 'community1', type: 'esriFieldTypeString'},
{name: 'streamcat', type: 'esriFieldTypeString'},
{name: 'wetlandcat', type: 'esriFieldTypeString'},
{name: 'floodplcat', type: 'esriFieldTypeString'},
{name: 'culvertcat', type: 'esriFieldTypeString'},
{name: 'sedimentcat', type: 'esriFieldTypeString'},
{name: 'basincat', type: 'esriFieldTypeString'},
{name: 'treescat', type: 'esriFieldTypeString'},
geometryType: '',
features: []
// Iterate over each feature in the layer
for (var f in fs){
Push(
out_dict['features'],
{attributes:
projectid: Text(f['PH_PROJECTID']),
phaseid: Text(f['PH_PHASEID']),
phasename: Text(f['PH_PHASENAME']),
phasetype: Text(f['PH_PHASETYPE']),
complyear: Year(f['PH_COMPLDATE']),
status: Text(f['PH_STATUS']),
stream: Number(f['PH_STREAMRESTORED_LFT']),
wetland: Number(f['PH_WETLAND_AC']),
floodplain: Number(f['PH_FLOODPLAIN_AC']),
culvert: Number(f['PH_CULVERTREPAIRED_FT']),
sediment: Number(f['PH_SEDIMENTREMOVED_CY']),
basin: Number(f['PH_BASINSTORAGE_ACFT']),
trees: Number(f['PH_TREESPLANTED']),
wac: Text(f['PH_WAC']),
subwatershed: Text(f['PH_SUBWATERSHED']),
community1: Text(f['PH_COMMUNITY1']),
streamcat: IIF(f['PH_STREAMRESTORED_LFT']>0, 'Yes', 'No'),
wetlandcat: IIf(f['PH_WETLAND_AC']>0, 'Yes', 'No'),
floodplcat: IIf(f['PH_FLOODPLAIN_AC']>0, 'Yes', 'No'),
culvertcat: IIf(f['PH_CULVERTREPAIRED_FT']>0, 'Yes', 'No'),
sedimentcat: IIf(f['PH_SEDIMENTREMOVED_CY']>0, 'Yes', 'No'),
basincat: IIf(f['PH_BASINSTORAGE_ACFT']>0, 'Yes', 'No'),
treescat: IIf(f['PH_TREESPLANTED']>0, 'Yes', 'No'),
//Return populated out_dict as FeatureSet
var mos = FeatureSet(Text(out_dict))
return mos
