I am preparing for a very large timber cruising project. I am a complete novice to using barcodes with Survey 123.
I need to assign two barcodes to each tree.
I will be provided with boxes of barcode tags that have not been assigned any data other than an ID/tag number. So I need to assign an existing barcode to a record rather than being able to generate a barcode with the record.
I would like to assign the tree data I collect for each tree to the barcode as we mark each tree. I have set up a Survey 123 form with a barcode field, but I think this field is only used to read data from the barcode to populate fields if I read the Survey 123 documentation correctly.
Perhaps, the ID number that comes with the barcode would be read and it will be simpler than I am thinking.
I would appreciate any help in getting started. Thanks!
