I am inserting points into an SDE version using FME, but after creating the point, I'm unable to edit the UT Attribute Data. My company uses UT-Editor (customised from ArcMap), and typically, when I create a new point in UT-Editor, a window automatically appears to fill in the UT Attribute Data.some fields are necessary to fill like Adresse and … However, since I'm inserting the points through FME, when I use the UT Attribute Data symbol to choose the point and fill the point in, the window does not open. How can I resolve this issue? Is there a specific method that would allow each new point to linkage to UT-Attribute Data by FME ? or How could open the UT Attribute Data window in UT-Editor for each new point ,come from FME ?
