Hello GIS friends,
I have created a field called 'createddate2' and I'm trying to populate that field in Field Maps Designer using the forms option so when people create features using Field Map or web Web Map the 'created_date' value is dynamically added to the new field (createddate2) field.
I have used this '$feature.created_date' expression in the arcade editor form but it does not populate when the feature gets created. It only populates if I go back to the feature to edit and click update.
Your input will be appreciated.
Thank you,
Abi
This is what I'm using:
