Hello Everyone,
Where can I get the latest Esri UN Electric Asset Data package with European UNC data model included?
The https://www.arcgis.com/apps/solutions/index.html?gallery=true&solution=5ito8rwshywjd9qen5ka8nixgth3z4bc&sortField=relevance&sortOrder=desc#home does not have this.
Any help on this would be great!
First download the Electric Utility Network Expanded model from ArcGIS Soutions https://www.esri.com/en-us/arcgis/products/arcgis-solutions/overview
After Unzip the file, open the file Electric Utility Network Expanded.aprx in ArcGIS Pro.
In the Catalog pane, in the Databases folder, you will see File Geodatabase named ConfigurationForBalanced.gdb. Open this Geodatabase and copy the two files, D_Configuration and D_Rename to the ElectricExpanded_AssetPackage.gdb.
Next you can use the GP Tool Asset Package Configuration Report from the Utility Data Management Support toolbox, in the folder, Asset Package, to see result of picking the desired options contained the configuration.
Once you are satisfied with your choices, you and use the GP tool, Apply Asset Package or Asset Package to Geodatabase, found in the Utility Network Package Tools toolbox, in the Asset Package folder.
Let me suggest you also looking into the white paper released and IMGIS 2024 describing in detail how to implement the UN data model to support balanced three phase grids:
https://www.volue.com/news/volue-and-elvia-release-white-paperA white paper that has been established based on years of experience data modelling and migrating to utility network for several very mature Scandinavian DSOs.
Thank you so much for the details @JohnAlsup.
I am new to ESRI Utility Network. I have download the
I have tried running create utility Network tool on the asset package it create duplication of structure layers. I am not clear how to proceed. how to used existing one and also developed UN for my electric dataset. Need proper guideline
Can you clarify what you mean by duplicated structure layers?
