Hi. I'm creating a python script which I'm going to publish as a geoprocessing service. The script is using the Zeep-library for connecting to a webservice (wsdl). I've written the script outside of ArcMap, and the script works fine when I run it. The wsdl is parsed and I can use the methods in the webservice. But when I try to run the script in ArcMap, I get an error
AttributeError: 'NoneType' object has no attribute 'utf_8_decode'
when I try to create the client:
client = zeep.Client(wsdl = wsdlUrl)
If I import the arcpy module, I also get an error saying cannot import name multiarray.
Have anyone used zeep in connection with arcpy?
I'm using ArcMap 10.5 and the newest version of zeep.
Regards, Torbjørn
