... Flex 3.0 ... Print Widget to export map to PDF and various other image formats. Is it possible to still use the same widget to print to hard copy AND export map? what are the tags/parameters I need to use?
I got problem to export PDF, as reported in the thread http://forums.arcgis.com/threads/61465-Print-Unable-to-Complete-Operation. Can you export your map successuflly? Thanks.
You would have to add the Print Widget twice, with different configuration files. Or go into the source code for the Print Widget, re-write the code, then compile it.
